ramihabchi
- May 1, 2019
- 98
Allowable bearing pressure by definition is the least between the allowable bearing capacity for shear failure and that for Having excessive settlement.
By excessive settlement they mean total settlement right?I mean having soil pressure below the allowable wont let me go on without checking differential settlement.
my second question:
Shear failure happens in a failure mechanism in which it depends on the total ultimate load and not on each point's pressure.So I think checking soil pressure to prevent shear failure based on a finite element software will be too conservative(having all point's pressure <qult),and it is better to compare mean soil pressure with bearing capacity.I was in doubt if this is correct but what made me convinced more is the definition of bearing capacity I have found on the internet:it is the average soil pressure that can be beared without shear failure.So am I right?I can only compare average values?
my second question:
