We are working on a Condensate polisher unit and require pH correction system at the outlet to raise pH up to 9.0 from 6.5
The conductivity at the outlet of CPU unit is <0.1 mS/cm
What are the typical chemicals used for pH correction. Is ammonium hydroxide an option?
What is the Commodity chemical name, typical concentration, dosing concentration, dosage rate for a flow of 225 m3/hr
Also advise the material typ used for such chemicals
NM
NM
