Chiller and Vacuum Recommendations
Random Engineer
3
Good day! I'm looking for Chiller recommendation that can use temperature range from -15 degree Celsius to -20 degree Celsius and Vacuum Pump recommendation that can be use vacuum air from -5 to -15 inHg. Any response would be highly appreciated. Thank you and have a nice day! [bigsmile] *I'm about to use it on Soap Making Machine* [bigsmile]
It sounds like you're looking for a small process chiller. I don't have a recommendation but it looks like boydcorp makes them. Try Vacuum Pumps America for the vacuum pump.
Try Busch for vacuum pumps.
I've used it in the past and are fairly robust and good construction.
