Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
For reducing the pressure drop there are some mechanism such as restriction orifice or nozzle and ... my question is which mechanism is governing?No. Nothing like it. It's designed to reduce pressure at very high pressure drop three phase fluid.
I think cc20 choke valve is very similar to converge-diverge orifice. Am I right?1503-44 (Petroleum)
142846 said:For reducing the pressure drop there are some mechanism such as restriction orifice or nozzle and ... my question is which mechanism is governing?
142846 said:If somebody asked us what is two difference between globe vale and choke valve, what is the answer? *except metallurgy". because both valves regulate flow and there are globe valves that could be installed at high delta pressure process.
