Chokeless wells and their advantages and disadvantages 1
Bahador66
Petroleum
Oct 13, 2022
Hello. I wanted to know what alternative things can be used in low pressure oil wells where the Choke cannot be used, because the fluid cannot flow due to its low pressure, and how to fix the things that the choke solves?
You can install a control valve at the inlet to the downstream separator. This CV can be configured to operate through a auto high or low selector switch which in turn receives the output from a high set PIC and a high set LIC at this downstream separator.
Whst's the fluid composition? All oil? What API?
What's the minimum and maximum pressures at the wellhead?
Einstein gave the same test to students every year. When asked why he would do something like that, "Because the answers had changed."
