Piline
Industrial
- Dec 13, 2021
- 10
Hello everybody,
I am busy setting up catalogs (dimensions) for 3D piping software. I once read an article about the relationship between ASME and MSS standards “MSS standards should complement the guidelines of the ASME documents”. In my specific case it is ASME B16.9 and MSS SP-75. There is a difference in the ranges but the dimensions are the same. Materials have a small overlap (A234 & A420). I have doubts about choosing the right standard. Here are some highlights of the standards;
ASME B16.9 Factory-made wrought buttwelding fittings
1 SCOPE
1.1 General
This Standard covers overall dimensions, tolerances, ratings, testing, and markings for factory-made wrought buttwelding fittings in sizes NPS 1 ⁄ 2 through NPS 48 (DN 15 through DN 1200).
5 MATERIAL
Wrought fittings covered by this Standard shall be in accordance with ASTM A234, A403, A420, A815, B361, B363, B366, or the corresponding standard listed in Section II of the ASME Boiler and Pressure Vessel Code.
MSS SP-75 Specification for high-test, wrought, butt-welding fittings
1 SCOPE
1.2 This Standard Practice governs dimensions, tolerances, ratings, testing, materials, chemical and tensile properties, heat treatment, notch toughness properties, manufacture and marking for high-test,butt-welding fittings NPS 60 and smaller. Dimensional requirements for NPS 14 and smaller are provided by reference to ASME B16.9.
6. MATERIALS
6.1 The steel shall be fully killed and made using recognized melting practices to provide intended heat-treat response and notch-toughness properties.
Steel shall be made by open hearth, basic oxygen, or electric furnace process and shall be suitable for field welding to other fittings, flanges, and pipe manufactured under the following specifications: ASTM A53, A105, A106, A234, A381, A420, A694, or the corresponding ASME standard, or API 5L, and MSS SP-44.
12. FITTING DIMENSIONS
12.l One of the principles of this Standard Practice is the maintenance of a fixed position for the welding ends with reference to the center line of the fittings or the overall dimensions, as the case may be.
Dimensional standards for fittings NPS 16 and larger are shown in Tables 3 through 9. Dimensional standards and tolerances for NPS 14 and smaller sizes are contained in ASME B16.9.
ASTM A234
1. Scope
1.1 This specification covers wrought carbon steel and alloy steel fittings of seamless and welded construction covered by the latest revision of ASME B16.9, B16.11, B16.28, MSS SP-79, and MSS SP-95. These fittings are for use in pressure piping and in pressure vessel fabrication for service at moderate and elevated temperatures.
ASTM A420
1. Scope
1.1 This specification covers wrought carbon steel and alloy steel fittings of seamless and welded construction, covered by the latest revision of ASME B16.9, ASME B16.11, MSS-SP-79, and MSS SP-95. These fittings are for use in pressure piping and pressure vessel service at low temperatures.
In my case, filling database with dimensions, the following questions;
1. Which standard should I refer to?
2. Do the Codes (ASME B31.x or EN13480) matter in this case?
3. If it is the ASME standard, in which case I refer to the MSS standard?
The database is currently not yet filled with a material type. A significant detail is that the ASTM standards (A234 & A420) do not refer to the MSS SP-75, but to the ASME B16.9.
For the range 1/2” - 24” I tend to refer to the ASME B16.9, is that correct?
Thanks in advance
1 SCOPE
1.1 General
5 MATERIAL
1 SCOPE
6. MATERIALS
ASTM A234
1. Scope
ASTM A420
1. Scope
Thanks in advance
