Circuit breaker rated current.
Mlmlzx
57
Sirs,
For a 31.76 MVA and 11 kV generator line current is 1667 amps. 11kV VCB rated current can be: 2000 Amps.
What could be the 132kV circuit breaker rated current if 11/132 kV transformer is connected?
The typical current rating of the 145 kV circuit breaker are 1200 A
to 4000A. For 1667 A at 11 kV equate to 139A = 1667x11/132. Therefore, the smaller current rating of 1,2000A can hndle the primary current
Or 2000A if that’s smallest size you generally use at that voltage level.
I’ll see your silver lining and raise you two black clouds. - Protection Operations
