Cladded Tubesheet to tube weld material clarification Required SA-266 Gr. 2/4N , SB-111, UNS (C7060
staticmh
57
Hi All,
Appreciate to have expert opinion from welding and material perspective.
Case details: Heat exchanger tube to tubesheet weld Joint
Tube sheet base material is SA-266 Gr. 2/4N
Which have explosion bonded Cladded face (10mm) with - CrNi 90/10.
Tube material = SB-111, UNS (C70600) (CuNi 9010), FINS-ALUMINIUM
Questions:
1- What will be the weld material for strength welding in between tube sheet cladded face material (CrNi 90/10) to tube (SB-111 , UNS C70600 (CuNi 9010)).
2- What will be impact of using silver brazing, need suggestion to evaluate it and to avoid any expected repair/failure after operation of HEX.
3- What will be the correct weld filler material ?
Thanks in advance.
What is the bundle?
Fixed tubesheets, floating head, U-bundle?
Is it mandatory that you use strength welding?
Could you not just use double grooved holes and expand only in case the tubesheets aren't fixed?
@CuMo
Its floating head.
Yes mandatary to do strength welding.
My query is pertained to welding material between tube sheet cladded face material (CrNi 90/10) to tube (SB-111 , UNS C70600 (CuNi 9010)).
When welding these you had better not be into the base metal at all.
This needs to be purely a CuNi-to-CuNi weld.
There are CuNi weld fillers.
I doubt that you could get away with braze as you would need to validate strength, fatigue, and corrosion resistance.
