Dear collegues,
I hope this message finds you well. I'm currently reviewing our project's structural design, and I have a question regarding the use of cross ties in concrete walls.
From my research in the ACI manual, I've noted that cross ties are explicitly mentioned for boundary elements of walls. However, I couldn't find specific requirements for their use in areas of the walls that are outside of the boundary elements.
Could you kindly provide clarification on whether cross ties are necessary for sections of the walls beyond the boundary elements according to the ACI code? If so, I would appreciate guidance on the specific code references or conditions under which they should be used.
Your insight on this matter would be extremely valuable as I consider submitting a Request for Information (RFI) to streamline our project requirements.
Thank you for your assistance.
Best regards,
Eng.Ghazwan Asaad PE,PMP
Best regards,
