solid34works
- Jun 30, 2007
- 41
- 0
- 0
I have to design a plastic reciprocating pump. Cylinder size is 3.126+/- 0.001. I will have to decide the piston size. I have already designed the O rings from the standard guides. I am not able to find any reference on piston cylinder clearance. Any help will be highly appreciated. I saw some of the IC engine piston cylinder clearance. Those clearances are very small.
Plus I am not sure if so small clearanc would work for plastic parts or not.
I would appreciate if someone could help me on this. I need to know the clearance between piston and cylinder.
