clearance
jim81276
31
Hi, friends
how much clearance between casing and impeller of pump centrifugal??
and where I can see papers??
If you take your words "clearance between casing and impeller of pump centrifugal" and type into Google, you will get a lot of information for your very general question.
Walt
Ok Strong, but axial clearance between casing and impeller of pump centrifugal? Or there document I can see
Thanks my friend
Axial clearance varies based on pump and impeller type, read the nameplate or the GA (General arrangement) drawing for the required impeller lift.
Best place to start with any technical pump enquiry is the pump manual or the manufacturer - not asking meaningless opened ended questions in Eng-tips.
