dthom0425
- Dec 6, 2018
- 46
Hi all,
See attached picture of representative part that I have. I'm curious of your thoughts.
This is a weldment. The tube gets welded into the clevis ends and the clevis ends mount to a receiving joint via the two slotted openings at the bottom and pin (two pins, one for each side).
I was planning on making the 2X slotted openings (the width) a datum feature, and the 2X holes a datum feature.
Would you guys agree with this approach or is there some other better functional set up of the datums?
THanks for the help.
