Kris the Engineer
- Aug 28, 2020
- 7
Hello all,
I have a general question regarding large CMU pilasters that are 32" sq and larger. a 32" sq pilaster with 8" block on the exterior, leaves a 16" sq hole opening in the middle of the pilaster. These pilasters are generally used as cantilever elements used to support fences or gates.
My question is if the center of the pilaster has to be grouted solid or can it remain ungrouted as long as the correct ties and reinforcement is used?
Thanks.
Thanks.
