I have codes for OKUMA machine, but i want to do the same machinins with MAZAK.and it takes so much time to convert the programs manually. Is there any way to do it automatically?
If you use a CNC programming software it will do all that for you. There are many different popular brands of it available. Bobcad will be the least expensive I think.
In the past I think Mazak could run either its specific programs or Fanuc equivalent? Its been many years since being around Mazak.
