CNC fillets
how would they create that fillet?
you could run a cutter (NC) around the corner. mind you, you could bevel the edge. or if it isn't critical, just a drawing note "break sharp edges"
Quando Omni Flunkus Moritati
Corner rounding end mill.
Thanks to all that posted I will look this up... :)
Design for Manufacture Guidelines often discourage this kind of radii that is being created by the form/shape of the tool itself because each size radii requires a custom tool which may mean a tool change etc.
This is why chamfers are often used instead as the same tool can make multiple sizes of chamfer.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
this fillet willadd to the cost of the part, maybe not much.
is it critical to the part's performance ? or is it "artistic" or just someone playing with the solid modeller ??
if not consider bevel (probably similar cost), or just breaking the sharp edges.
Corner rounding is often done in place of chamfering because a chamfer is still an edge, albeit obtuse. A radius lends to aesthetics and ergonomics and adds perceived value. The time spent machining is no greater than for a chamfer, and it would be unusual to mix multiple edge radii on the same part. It also reduces stress concentrations in more critical parts.
I would assume since this would be using a corner end mill that you would have to manually rotate the part along the edges to create the fillet around the part? or could this be programmed into a CNC machine tool path to do it?
cnc does this for you
when correctly programmed...
If you also have the fillet on the bottom side then the block will have to be flipped over.
