Buildtech2
We have designed carpark ventilation system with 6 ACH at normal mode and 12 ACH at fire mode which is in line with NFPA and local regulations. However, following is also mentioned in NFPA 5000.
As per life safety code, NFPA 5000, (Ch. 49 CL.49.2.2.5) which specifies - Enclosed parking structure shall have a ventilation system designed to limit the concentration of carbon monoxide to not more than 35 parts per million of air when measured between 36 in. and 48 in. (915 mm and 1220 mm) from
the floor”.
We need to justify to our client that the ventilation system so designed will attain above code
requirement. Appreciate, if anybody can guide me on this.
the floor”.
