Hi All,
Looking for code calculations to determine the thickness of the flat plate to blank leaking tubes in the shell and tube heat exchanger and the weld thickness.
Shell:
Material - 304L
Medium - Air
Pressure - 6 bar
Temp - 120 C
Tube
Material - 304L
Medium - Saturated steam
Temp - 215 C
Pressure - 25 bar
thickness - 1mm
Tube dia - 16mm
Tube plate
thickness - 20mm
material - 304L
We have found some leaks in the heat exchanger tube, the manufacturer recommended that we cut the leaking tube flush with the tube plate and weld a flat plate on the tube plate. The removed tubes will be sent to manufacturer to determine the failure cause.
My two major questions
1. I have used the UG-34 calculation to determine the thickness of the plug. I understand this calculation is for heat exchanger/pressure vessel heads but can this be used to determine the thickness of the flat plate required to plug holes and corresponding weld thickness.
2. The tubes are seal welded on the shell side of the HX. Adding a fillet or bevel weld on the tube side will restrict the thermal growth of the tube with the 20mm tube plate. Is this going to be an issue?
Thank you for your help/advice in advance.
Shell:
Material - 304L
Medium - Air
Pressure - 6 bar
Temp - 120 C
Tube
Material - 304L
Temp - 215 C
Pressure - 25 bar
thickness - 1mm
Tube dia - 16mm
Tube plate
thickness - 20mm
material - 304L
