JaseSymons
Hi all
I'm working (in UK) on a sulphur dioxide line(<10 bar) which the PED and client line lists classify as SEP. The client line specs however specify ASME 31.3 and class the pipe as Cat 'D' while under ASME I believe SO2 would mean a Cat 'M' classification. I'm confused. Which classification takes precedent? Would Sound Engineering Practice be to use Cat 'M' section of Code?
