Code help
Jmccarthy
Geotechnical
Mar 24, 2010
6
I have created a model in CAE and i need to remove a part in a certain step. To do this i think i need to write the following in the step part of the .inp file
*Model Change, Remove, Type=Element
Element set name
When i do this and then submit the job the two lines i put in gets erased and the part i tried to remove still remains in my model. Any suggestions?
As far as I'm aware Abaqus doesn't edit the .inp file but merely reads it. Me thinks you've not saved the .inp file after you edited it.
ex-corus (semi-detached)
If you use keyword editor (Mode->Edit keywords) in Abaqus/CAE to edit the .inp file, the changes in the .inp file would be preserved when a job is submitted from Abaqus/CAE.
I think there was a bug in one version of cae so that when you thought you had changed the .inp file using the keyword editor, it had in fact done nothing. I now always check the .inp file after using the keyword editor to make sure that the changes have appeared, and that no *conflicts appear to screw things up.
I think i got. I had tried to go into the input using wordpad. I didnt know about the keyword, first couple of week with the program and im teaching myself... somewhat.
