Hi all,
I am assigning Cohesive zone surface interaction parameters as mentioned below in interaction module between bolt and concrete surface.
Knn, Kss, Ktt, Normal only, Shear-1 only, Shear-2 only, damage evolution parameter.
As far as I searched in the literature, in each paper different formulation is adapted to define the parameter.
For example:
1) Diehl T. Modeling surface-bonded structures with ABAQUS cohesive elements: beam-type solutions. InABAQUS Users’ Conference 2005 May (pp. 1-27).
Keff= Tult/ displacement at cracking stage
2) Turon A, Davila CG, Camanho PP, Costa J. An engineering solution for mesh size effects in the simulation of delamination using cohesive zone models. Engineering fracture mechanics. 2007 Jul 1;74(10):1665-82.
K= alpha * E/t
3) Nguyen HT, Kim SE. Finite element modeling of push-out tests for large stud shear connectors. Journal of Constructional Steel Research. 2009 Oct 1;65(10-11):1909-20.
Knn= 0.1Ecm
And also how to choose the normal stress values for damage initiation criterian?
I am running time history history analysis. The analysis stops at the middle depending on the damage parameters chosen.
Can anyone guide me how to choose the parameters to avoid convergence issues?
For example:
K= alpha * E/t
Knn= 0.1Ecm
