OriginalTexasRanger
Hi all,
The company I work for is a MEP subcontractor, we are working on the installation of a small hotel (30 storey) where open vent storage type calorifiers are used in combination with heat pumps (helps provide Chilled Water for A/C system) to preheat potable water before it is fed to gas heaters and then to hot water taps.
The current design feeds cold water to primary side (tube) [15°C, in 32°C out] of the calorifier while the heat pump hot water feeds the secondary side (storage) [45°C in, 40°C out].
I've done some reading up online, and it seems that most descriptions have the hot water source to feed to the primary side, while the cold water are fed to the storage side.
I've spoken with the consultants, and they have said that the reason they have designed it in this way is because the calorifiers & heat pumps are located @ 5/F, while the hot water has to feed to the upper floors, in which case, the cold feed has to be pumped as well. To prevent water escaping from the calorifier air vent, they have decided to put the cold feed to the primary side.
Are there any particular difference whether the cold water is fed to primary or the secondary side?
My intuition is that, putting the air vent issue aside, it would make more sense to have the cold water on the secondary side, since that would mean a reserve of hot water on demand for the water taps, since the chilled water demand can fluctuate, therefore the heat pump hot water source is not a "reliable" source of heating. And without some kind of mixer, when the instantaneous demand peaks, the hot water temperature around the tubes may be locally lower than the bulk of the water in the storage tank, reducing the heating capacity of the tube. All taken together, it would seem that the gas heaters would just have to work harder than it needs to because the calorifier isn't as efficient as it can be.
Anyway, just my thoughts, it would be nice if someone can educate me on this subject. Big thanks!
KH
[I am actually not from or anywhere near Texas, just that as a child, I used to watch Chuck as the Ranger!]
KH
