dgillette
Geotechnical
- May 5, 2005
- 1,027
Got a weird one here.
I'm dealing with an old dam that has shown some minor cracking recently, for which there are a couple of plausible explanations. One of them is collapse on wetting.
There are three main kinds of fill in this embankment, hydraulic fill, "rolled" fill (primarily CL), and rolled fill. The distinction between the last two is pretty big. The "rolled" was probably dumped off of wagons, and spread with horsedrawn Fresno scrapers, with little or none of what we would consider rolling nowadays. There is also an overlay of dense, for-real rolled fill put on 10-15 years ago for seismic reasons.
1. They had the wettest spring and early summer in anyone's memory.
2. When we drilled it ~15 years ago, unadjusted SPT N was mostly 2 to 5! I don't have dry density, but it can't be very high.
3. Moisture contents in the "rolled" were consistently lower than the PL; MC 13-16, PL 20-22. (The material is practically all -#40, so I'm not getting tricked by the presence of +#40 in the MC sample and not in the Atterberg sample. Already checked that. In fact it is mostly 90-95% -#200.)
While I've never heard of collapse potential in manmade fill, with such low N and MC here, it would seem possible. Ever seen anything like that happen? We don't have much info beyond water content, N, grain-size distribution, and Atterbergs. Unfortunately, unless we decide this is a serious dam-safety problem (which I doubt, because of the overlay and the unusual geometry of the dam), I won't have any money for drilling or testing, dangit.
The underlying hydraulic fill is similar, but for having much higher moisture contents (a little below LL), and slightly higher unadjusted N. (Yes, higher N in the hydraulic fill than in the dry fill.)
Settlement in the area of the crack and at one other place accelerated quite a bit this summer, something like 0.3 feet, whereas previous settlement since the overlay was put on was more like 0.2. (No info before the overlay in the late 90s.) The geometry of the crack would fit with collapse of the dry fill or consolidation in the underlying hydraulic fill, although there is no reason I can see for the hyd fill to suddenly start to consolidate again in wet weather.
I have experience with only a couple of collapsing soils, one of which, for fattdad's interest, was the slopewash in Tim S's dissertation. The other was a collapsing silt we were having to pre-wet before we built a canal in it / on it, >20 years ago.
Cheers!
DRG
Cheers!
DRG
