1
- #1
Hari1207
- Mar 9, 2020
- 14
Hi!
Currently I'm taking care of Shell and Tube Heat Exchanger design and this is new to me.
For the BKU TEMA type, as per project specification, Full-diameter stationary tube sheet to provided with 25% Collar bolts.
I found in the calculations that Channel Side test pressure is more than the Shell side test pressure (As Channel side Design Pressure is more than Shell side and considered DP as MAWP). I suggested that collar bolts and other channel flange bolts can be used to hold bundle and Channel together during hydro test and no need to use Test Rings for Channel Test.
But this had been rejected from my counter-part by saying that Collar bolts are used to hold Tube and Shell only during removal of bonnet.
I got a doubt that why my idea was not acceptable?
Could anyone explain me why I should not use the collar bolts in that way? what is the logic behind it?
Also, I would like to ask that are we allowed to hydro test the kettle? since one of my exchanger manufacturers suggested me that we can use dummy shells to check for shell side gasket leaks. No need to go for Kettle, as the volume of kettle is more, tubes and other internals may fail during test, he says.
Please comment your views on this too.
Thanks in advance.
Thanks in advance.
