I am working with NXopen .NET Code for creating Linear PMI dimensions dynamically, for that I have created attributes to FACE objects, identifying such faces with attributes it collects faces and put Linear PMI dimension to it. The issue is in large assemblies, its painful to loop thru each Part/Bodies/Faces and extract face which has matching attribute. So is there any UF API using which FACES with attributes can be collected directly?
Chetak
SIEMENS ENERGY / Knowledge Based Engineering
NX11.0.2.7
Chetak
NX11.0.2.7
