Colour Image with BatchShadeOptions
basenxuser
IN
Hello All,
I am trying to achieve a colorful shaded image of display using the following command:(But it is giving monochrome image). Any suggestion will help.
Dim options As New UFDisp.ShadeOptions
options.disable_raytracing = True
options.distribute_excess_light = True
options.facet_quality = 1
options.resolution = 400
options.plot_quality = UFDisp.ShadePlot.PlotFine
options.generate_shadows = False
options.transparent_shadows = False
options.fixed_camera_viewing = False
options.super_sample = 3
options.raytrace_memory = 128
options.subdivision_depth = 6
options.radiosity_quality = 15
options.distribute_excess_light = False
options.use_midpoint_sampling = True
options.format = UFDisp.ShadeFormat.FormatRaster
options.display = UFDisp.ShadeDisplay.DisplayNearestRgb
Dim X_size As Int32 = 640
Dim Y_size As Int32 = 480
theUFSession.Disp.BatchShadeOptions("C:\demo\Images\Test.jpg", X_size, Y_size, UFDisp.ShadeMethod.PhotoReal, options)
basenxuser
This looks to be a "high quality image" (or rendering) type of operation; have you applied materials and/or colors to the bodies to be rendered?
www.nxjournaling.com
do you have the license for "high quality image" rendering ?
( the name of the license feature could be "studio_render" .)
If one doesn't have the license when rendering interactively, , NX renders in Phong or if it was goraud , very basic appearance.
Tomas
Hello All,
Solved the image creation issue by setting the environment variable NX_RTS_IRAY=0.
basenxuser
