In higher Seismic Design Categories, when using the equivalent lateral force (ELF) method, earthquake loads are applied as 100% of the seismic force in one direction (X or Y) and 30% in the orthogonal direction (ASCE 7 provisions).
However, when using dynamic analysis (modal response spectrum analysis or time history analysis), earthquake forces are considered 100% in both the X and Y directions simultaneously.
My Question:
• When designing a column using ELF, we obtain moments Mx and My based on the following load combinations:
• For My: 1.2D + EQx + 0.3 EQy + 1 (0.5) L
• For Mx: 1.2D + EQy +0.3 EQx +1 (0.5) L
• We then design the column as a biaxially loaded column with moments Mx, My, and axial load P, correct?
In the case of dynamic analysis, we apply 100% of the earthquake force in both X and Y directions, and design it as biaxialy loaded?
My Question:
