structSU10
Lets say you have a steel column, of height L, and need to know its vertical natural frequency. using f = sqrt(k/m), k = A*E/L and m = ρ*A*(L/2) [assume half of mass is effective due to variation across height] , then f=sqrt((A*E/L)/(ρ*A*(L/2))) which reduces to 2*E/L^2*ρ - essentially showing that no matter how stocky the member, the natural frequency for the steel columns will be the same. Is this strictly correct?
I have a frame that must meet strict natural frequency criteria, and is tall enough that the column alone cannot meet the criteria. Should I be pushing to get a more refined criteria, or is there a way to improve the frames frequency even with the issues at the column?
