Column Reaction Forces/Moments
EngrJS1
PH
In analyzing my reinforced concrete structure, I found that there are large support reaction moments at the bottom of the column. What are the ways to reduce the magnitude of these moments? Will it be reduced if I added additional beams connecting the columns?
What sort of structure is this?
Please post sketch or image along with loading.
One of the options, modelling the supports with springs ( rotational springs ) ..In general , engineers model the support joints assuming full fixity ..You may calculate the rotationa stifness of the footings and introduce to the model.
A sketch would help ..
Before considering a solution, you should find out the reason/source that has caused the large support reactions. It can be a simple mistake in the framing model.
Pin it at the bottom, problem fixed. Adding beams might attract more lateral forces and increase the moment at the bottom.
