jochav52802
Good Day,
I've got an existing base plate for a fixed-based steel moment frame structure that is supporting some new and higher seismic loads under the jurisdiction of the 2019 California Building Code.
As a result, the existing cast-in anchors aren't sufficient to carry the uplift forces. Therefore, I'm considering having new post-installed anchors installed in between the existing anchors to achieve the desired capacity.
I'm unable to find any supporting design materials that allow or consider cast-in anchors combined with post-installed anchors.
I'd appreciate any support or references that you can provide on whether this is conventional and how I might go about the design; thank you!
