Gus14
- Mar 21, 2020
- 194
When designing a combined footing, we use the total load on both columns to find the resultant and then we size the footing accordingly to maintain that the center of loads and areas coincide. However, what if depending on the actual loading case one column gets loaded the assumed loads, while the other gets loaded less. This would result in an eccentric combined footing, I know that most of the loading is dead load and only the live load portion is changing but still this idea is bugging me, wondering if other engineers address this situation or if I am thinking too much about the whole situation, and I don't want to overdesign.
