KootK said:
The only engineering consequence that I could think of would be related to dynamic & fatigue loads potentially. While full strength is developed across the depth of the weld, I would not expect the welds to be uniformly identical from a ductility perspective across the depth of the weld. That said, off of the top of my head, I don't recall any specific requirement in this regard.
The only thing I can think of that gets close to this (at least from a code perspective) is if it is a CJP weld that is made from one side and utilizes backing. The backing (and its attachment to the structure) can cause fatigue/ductility issues, which is why it is required to be removed in some seismic design applications.
phamENG said:
To the tail with 'CJP' on it - I agree that it's justified sometimes. If you are doing the connection design, then it is not justified - you should select the appropriate weld and specify it.
I disagree. If a CJP weld is required and that is the only requirement you, as an engineer have, there is no reason to be dictating exactly how that CJP weld should be accomplished. Let the fabrication shops select their preference. If you are working directly with a specific shop and you know what their preference is, sure go ahead and put it on their, but if not, I don't see how it is helpful to be adding more restrictions than necessary.
MotorCity said:
I guess my question is, if they all develop the full strength of the base material, why not just use the weld type that involves the least amount of weld material all the time (whichever one that is)?
Weld economy is based on more than just the amount of weld metal deposited. Other major expenses that come into play:
- backgouging, which is required when performing a two sided CJP weld.
- edge preparation, a 2 sided weld requires more edge prep
- material handling, a 2 sided weld requires parts to be flipped over and handled more
- backing, a 1 sided weld will typically require the addition of backing
AISC's Design Guide 21 has a fantastic discussion on weld economy in chapter 17 (well the entire chapter is dedicated to just that)
It summarizes that, "single-sided welds are usually easier to prepare and make, making them preferable to double-sided welds when distortion control is not a concern"
That sentence also hits on one important topic - distortion control. A single sided weld will have a lot more material deposited on one side, which can/will cause excess distortion unless it is restrained or prevented.
