I have a condition where the bottom floor of a 2 story building will be open. The end columns I have designed as moment frames. The columns are round HSS14x.625 columns. For protection, the arch would like to wrap the columns in concrete. I was thinking of having studs welded to the column so that it would act as a composite column and the concrete would move with the steel. Currently, I've designed it to meet all loads as a regular steel column with 1" of drift. If I was to do this should I show any reinforcement, wire or ties around the column for crack control?
Another option is to use a double sono tube around the column so that there is a hoop of concrete around the steel column that could move independently of the steel.
Any thoughts on either method?
