FootNMouth
In our market composite steel beams with concrete on composite metal deck is a common framing system, however it's cost increases dramatically on smaller projects (footprint less than ~10,000 SF) due to many reasons with one being the cost of renting the Nelson stud guns to install the shear studs. For this reason, a popular system on these smaller projects is steel joists with concrete on non-composite form deck. Typically the joists are spaced at either 2' or 4' on-center.
Question: Are there reasons why using composite metal deck on either non-composite steel beams or non-composite open-web steel joists should be avoided?
The advantage of using composite deck in lieu of non-composite is much large live loads can be obtained and/or greater spacing of the framing members can be achieved.
Possible Floor Systems Described Below
1. Composite steel beams w. composite steel floor deck (e.g. 2VLI)
2. Steel open-web joists w. non-composite (form) deck
3. Non-composite steel beams w. composite steel floor deck.
4. Non-composite steel beam w. non-composite (form) deck.
