AmberAardvark
Hi All.
This is my first post so hope it is all correct.
I have some prints to check where the engineer has used composite tolerancing for some hole patterns, they seem to be very my just plug and play values for the hole clearance from the CAD software. On preforming the fixed and floating fastener formula which segment should be considered in the formula the upper which constrains location and orientation of the pattern, or the lower which constrains the location and orientation of individual holes within the pattern?
The more my head spins, I keep coming back to the lower segment as this controls the holes pattern to each other.
Any advise is welcomed, thanks.
