Torres_Structural
(Location: USA)
Currently working on a walkway that spans about 15 feet between supports. The I'm going with a deck that's about 2" in height and 6 inches of concrete cover. The deck sits on top of two Wx steel beams that span the 15 ft and are 8ft apart, with 3 foot cantilever deck on each side of the walkway. The steel beams are designed for composite action. My question lied more on the metal deck composite action. The deck was checked for the construction loads, i.e., weight of wet concrete and construction live load. the deck works with a 18ga 2CL deck (Vulcraft product). What would be the approach of designing the reinforcement on the metal deck slab. The cantilever gives a negative moment that needs to be resisted, and most of the literature of the composite action of deck and concrete (from vulcraft) does not mention a cantilever condition. Can anyone point me in the direction for resources or help on the reinforcement calculation for the applied loads at the cantilevered portion of the SOMD. Im superimposing 50 psf dead load and 90 psf live load. TIA
