First define what you mean by ACFM.
It could and probably is the way pedarrin and eng tool box define it ( i.e. taking note of the inlet conditions that exist at the actual location of the compressor,
OR
it could be the actual volumetric flow that is happening with gas compressed to 125 psig.
If the former, then the pressures are irrelevant, it's the cfm that defines the mass flow. In most locations acfm will be a lower mass as actual conditions are usually lower than standard conditions.
If the latter definition then it's probably the other way around.
