Compressibility of Nitrogen Gas and Liquid Water
tb012
1
I need to pressurize a volume of 4823 cubic inches to 9500 psi using a set volume of water and nitrogen gas on top. What I don't understand is how to relate the compressibility of the gas to the volume of water and nitrogen needed. The temperature will be around 80 degrees F. I need to develop a relationship to determine the volume of Nitrogen needed, using the compressibility of Nitrogen, pressure of the chamber, and the water volume. Is that enough known information to develop the equation?
Compressibility factor z is roughly 1.61 for N2 at this high pressure from T-S diagram of N2 in Perry Chapter 3
Find n
n=P.V/z.R.T
n= kgmoles of N2 gas
V= actual volume of gas space in m3
P=pressure = 656e2 kpa abs
R=8.314kJ/kgmole/degK
T= 300degK
Actual mass of N2 required, kg = n x 28
Standard volume of N2 required, Sm3 = n x 23.645
Henry's Law solubility of N2 in water is most likely small and is ignored here.
Accounting for N2 solubility in water at 655 barg, Google tells me H = 6e-5 / MPa, where solubility of N2, the Henry's Law constant, is expressed as mole fraction of N2 / kgmole of water. Simplifying, this works out to 6.2kg of N2 dissolved / m3 of water. Add the corresponding mass dissolved in your volume of water to the mass of N2 in the gas space. Note : Standard volume for gas in Sm3 references 1atm, 15.6degC
George,
My calculation using PR EOS is 1.42 for Z at 26.66C and 656 bars Abs.
Pierre
