Italo01
- Sep 4, 2021
- 169
Hello, i just design a steel building with non-structural masonry( The walls are located inside the column flanges). Yesterday i found an article called "compressive strength of steel columns incased in brick walls" by Albert Harris in which tests where made with bare columns and columns incased in structural masonry walls and did show that the column almost reaches yield stress.
I did not consider any masonry restraint on the column and do not intend to use it but would like to know what you think of this situation. Does the masonry increases the column strength?
Thanks.
Thanks.
