compressor
kuldeepmodi
Chemical
Aug 11, 2009
Hi friends ,
I am doing simulation of Gas compressor .
I want to know How the compressor will behave when input control valve of the compressor is on , dischrage controlvalve is off and antisurge controlvalve is also fully open.
should itbehave like pipe module ?
what is equation of volumetric flow at that time ?
it will act like a blocked line as there is no exit from the unit. Then depending on where the anti surge take off is, it could act like a blocked in heater with the fuel valve locked open.
