Hello There
Iam about to start project in my plant and i need your help guys
we have a compressors room and i need to install ventilation system for the room
there is :
1- Two Compressors Water Cooled ( Compressed Air Flow : 710 m3/hr ) (Motor Kw : 75 ) There is a cooling fan to cool the motor and also to cool the oil cooler (air cooling flow rate : 12240 )
2- Two Compressors Air Cooled ( Compressed Air Flow : 841 m3/hr )(Motor Kw : 90 ) (Air Cooling Flow Rate : 17620 m3/hr )
all compressors has an exhaust duct to take the hot air outside the room
The Room Temp in summer gets high and sometimes trips the compressors
My Questions is
1- Do I need to install supply fans with exhaust fans , Or Just Supply fans and already there is an exhaust for each compressor
2- What is the total inlet flow rate needed , Do I Consider also the water cooled compressors in my calculations ?
there is :
My Questions is
