Just wondering if anyone else has or is experiencing corrosion of Alloy 20 gaskets with 93% sulfuric acid? Had a valve flange and gasket get corroded away in a deadleg right off of the acid tank far away from any water getting to it. All material is Alloy 20 and the deadleg is from the middle of a 3" tee that's welded to a RF flange and that's where the valve was bolted in. Operates at about 85 degrees F. This isn't the first gasket leak but the furthest from water in the system we have had. Is it possible that condensation is somehow forming inside at these flange locations causing the problem? That's the only thing I can think of as to how this would keep happening like this. Thanks for any ideas, experiences, comments, etc!
