Hello.
i am currently design a massive 100/100cm beam monolitic connected by the top part to a 30 cm thick slab.
The beam experince certain torsion, But it is being restrained by the concrete slab which is capable of taking the torsion as concentrated moment at the edge.
My question:
does my logic sit well with your experience? is there any code referencing this force transfer?
when and if i model the slab as rotational spring support. what would be the equation concrete slab to rotational spring support (i assume its not even linear due to cracking)
My question:
