YunJW
- Nov 5, 2017
- 4
Hi all,
In "AASHTO LRFD 2012, Bridge Design Specifications 6th", there is rule for splice in column of seismic zone 4 as below.
'clause 5.10.11.4.1f - Splices
The spacing of the transverse reinforcement over the length of the splice shall not exceed 4.0 in. or one-quarter of the minimum member dimension.'
In connection with the 5.10.11.4.1e - spacing of transverse reinforcement for confinement, I understood that it is applied inside the plastic hinge region. However someone talked to me, it should be applied all region of columns.
Could you please help me?
what is more precise interpretation?
or where do this rule come from?
Thanks in advance.
Thanks in advance.
