Francis666
Hello guys. My friend modelled a reinforced concrete beam. Problems faced are The plasticity/creep/connector friction algorithm did not converge at x points in ABAQUS. I edit step but problem persists and job is aborted.
She also defined a boundary condition which is pinned. and also a displacement (-50mm) as she wants crack stop at 50mm.
a)Should she use a xfem crack method to correct the model to so that crack stop grow at 50mm?
or what correction can be made? for example, to boundary condition
b)visualisation from aborted job only shows beam, but stirrup and steel are missing and there is no crack and beam no moves downward. Should she insert loading?
c) what are some ways i can control growth of crack at the beam?
May i have someone gives suggestion/ checking model? Urgent. Thanks for opinions, guys.
