Everynameistaken
- Jun 29, 2014
- 68
We are looking at two items, concrete demolition in which we need to remove several inches and expose the existing reinforcing and secondly to prepare an existing concrete surface to receive new concrete.
We have a tech spec that allows the concrete to be removed via chipping or light jack hammer but we want to make sure we are able to reduce the incidents of microcracking/ bruising. This can be done by coming back and blasting with high pressure water jet. What I am trying to figure out is at what pressure of water will we be removing the surface with any micro cracks? Is it a commercially available pressure washer or does it need to be a hydro demo tool?
Secondly, we need to prepare some old concrete to receive a new concrete structural layer above. We have asked for "intentionally roughened surface to 1/4"" which is pretty standard and easy to achieve with new concrete by greencutting. On old concrete the contractor is looking into different means, one is hydrodemo which is perfect, but maybe cost prohibitive. The other two are mechanical methods, either bush hammering or mechanical scarifiers or scabbers. My concern here again is bruised concrete or micro cracks, and the need to come back over with high pressure water or very high pressure like a hydro deom tool.
Any thoughts would be appreciated,
