Hi guys,
I am trying to design a concrete mix. I will use the concrete for casting counter tops and small things like vases and other alike.
I have attached a screenshot of my design mix.
From what I have been reading a ration 1-1 - cement to sand will produce a very high strength concrete (the cement that I am using is of class 42.5 N/mm2).
Due to the fibers I cant really find out what the tensile strength is, but it should be quite high, because I made a plate (0.5x0.3x0.02m), placed supportes at both ends and jumped on it and I didn't see a crack.
In my opinion the mix design is okay, but if someone knows a way to improve the design I am open to suggestions. Also is there a way to calculate the curing time. I was casting some ashtrays in a silicone mold and some of them I can get out of the mold in a day and a half and others when taking out are cracking.
Best Regards,
Tsvetan Donov
Best Regards,
Tsvetan Donov
