Charlie Delta Whiskey
- Aug 16, 2017
- 18
OK, I have searched and searched and even emailed old professors but I can't find an example of how to calculate the required spacing of rebar in concrete shear walls. Maybe its because it is never a big concern and usually the concrete has sufficient shear strength. I usually dont ever deal with concrete shear walls but sometimes I need to show calcs for an ICF (insulated concrete form) building. So I tried calculating it the same way I would calculate the required shear reinforcement in a concrete beam with a few modifications. Attached are my calcs. Does that look like it could be correct or am I way off? Are there other requirements (minimums/maximum rebar spacing, etc.) for concrete shear walls? What about requirements for special reinforced concrete shear walls? Any help, suggestions, tips, guidance would be greatly appreciated.
Happy Friday everyone!
