Hi all,
I am working on an underground structure with strict crack control requirements. The perimeter walls are subjected to high out of plane flexural forces along with the axial compressive forces.
Does anyone know of a good program or reference for developing serviceability interaction diagrams? There are plenty of resources for designing beams for limiting crack widths but nothing that I can find for axially loaded members.
I would ignore the axial load but that would result in very high reinforcement ratios. I would like to utilize the axial loads to reduce the reinforcement ratios.
My other thought was to calculate the maximum allowable rebar stress for the max crack width/assumed rebar spacing and then use that stress as the yield stress in a regular concrete strength interaction diagram. This isn't correct either as it assumes a equivalent rectangular stress block instead of the triangular stress distribution.
Any help would be appreciated. Thanks
