I have gas at 1500 psig dropping to 850 psig across a JT valve.
The resultant condensate from the letdown flows into a 2 phase separator through a Schoepentoeter baffle with liquid flowing out to further processing and gas coming out through a demister.
I am seeing at certain times a DP across the separator of 40 psi (usually DP <2 psi) and I cannot understand why as no other process conditions change.
I thought at first it was hydrate formation but I ran HYSIS simulation and crystal formation is not possible at these conditions (water content <0.2 lbs/mmscf).
I am at a loss as to why I experience this DP and it does not cause me any problems, no other process changes.
Only thing I notice is it happens at high ambient temperatures in afternoon (I am in Middle East so quite hot).
Instrumentation is fine, it's a genuine DP.
Anyone ever experienced this ?
