kentucky08
Industrial
- Jun 24, 2024
- 3
Good day, everyone,
I am currently calculating the chilled water capacity required for our Methanol Refining Unit. The chilled water will be supplied to the total condenser. From this, we can conclude that the capacity of the chilled water will depend on the methanol vapor fed into the total condenser.
Before reaching the total condenser, the vapor will first pass through the first condenser. In the first condenser, most of the methanol will condense, and the vapor will exit from the upper part of the shell to be directly fed into the total condenser for further methanol recovery.
I have the temperature of the methanol vapor feed and the temperature of the uncondensed methanol that will be fed into the total condenser. Additionally, I have the design data for both condensers, including the number of tubes, tube orientation, pitch, length of tubes, tube size, and shell diameter.
My question is, with this data—particularly the temperature of the uncondensed methanol (i.e., the methanol that will be fed into the total condenser)—can I calculate the amount of methanol vapor fed into the total condenser?
